I would like to add an x,y,z jog command at the end of the cutting operation. This is for a plasma table.I want to jog the cutter over an uncut area of the table to avoid water splashing while the plasma cutter goes through the torch cooling/post flow process. Is this a G0x12,y12,z2 command for example?
Add x,y,z jog to end of operation
Re: Add x,y,z jog to end of operation
The simplest way to do this is to use the parking position. In SheetCam go to Options->job options->parking. Turn on 'Use X' and 'Use Y' then enter the coordinates you want to move to.
Thank you, I will try that. Sounds like that will do it.
