post for centroid
bphillip2
post for centroid
Post by bphillip2 »
I have a centroid router I use for cutting fabric, foam, wood etc. I now have a tool changing spindle that I insert tool into manually. I see a note on the post that says "use g43 tool length offsets" but it does not actually put the "H" number in the code. It does add "g43 D0" to the code.
How do I get it to add the Hx(tool number)?
Centroid M400 post processor
Modal G-codes and coordinates
Comments enclosed with ( and )
Incremental IJ
uses G43 tool length offsets
I'm thinking something is needed here:
function OnToolChange()
post.Text (" M6 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
post.Text (" G43 D")
post.Number (toolOffset * scale, "0.###")
post.Eol()
Bryan
Re: post for centroid
Something like this should do:
   post.Text (" M6 T")
   post.Text (" G43 H")
   post.Eol()
bphillip2
Post by bphillip2 »
That was quick, looks correct in post. I'll try it in real life.
