hans wrote: ↑Sun Mar 07, 2021 5:05 pm
Grid Color
When selecting "Grid options" via right click, the grid color is resetted to black
Fixed for the next release
"Loading default toolset" icons
I installed v7.1.1 on a clean VM and there the buttons for loading the default toolset are correct. But on my machine where I updated to this version they are still wrong. Any Idea?
Ah, the installer is trying to be clever. It does not overwrite files that are the same age or newer. I have changed the date stamps on the icons.
Another thing that only happens in the updated 7.1.1 is that the machine and workpiece is not shown. Only disable and re-enable this view makes the material appear.
I can't replicate this one. When exactly does this happen?
Translation files of context menu
I noticed that there is no de.mo any longer. Have you merged these files together?
I'll add them in the next release.
But I think that was the place where the translations for the right click context menu was stored. In the last linux version that was correct.
Anyway, this context menu is no longer translated except one resp. two entries.
Oh, that's a bad one. I'll fix it straight away.
Is it now my turn to complete the new message.mo file? If yes - could you then please update the file and remove all items that are not used any longer? (if this can be done automatically)
You should find a file called messages.pot in the Languages folder. This contains the latest translation strings. In Poedit load your translation then select Catalogue->Update from pot file. Open that file to merge the files. It will automatically remove any unused strings.
Path Rules
When canceling "Add new rule set" it seems afterwards that the existing rule is deleted:
It does not delete any existing rules. It just blanks out the options as you have no rule currently selected. You can select your existing rule set from the 'Rule set' dropdown. In the next release I'll make it revert to the first rule set.
