Cutpath issues with Layer
dualscott
Post by dualscott »
Had software operational until I installed the Rotary plugin, (Its in flat sheet mode currently). Anyhow if i import a DXF i can successfully generate a plasma cut path, but if I use the duplicate feature I get a layer not found error and no cut path is generated, not even for the original part. Not sure what im missing, the only change I'v made was activating the rotary plugin, which I have not used yet.
Thanks!
