New computer
New computer
Hi guys new to this forum. I have been running sheetcam for about a year now on windows7 with no problems. Just upgraded to new computer with windows 10 and now when i post process it does not give me any of the warnings in the post process report and when i load gcode into mach 3 it will not display the images and has " Nested comment found" in the status bar. Has any come across this and if so what is the fix please
Re: New computer
Are you using the same post processor as before?
Re: New computer
Yes using the mach3 plasma processor
Re: New computer
Is your g-code file very short? It could be that you have a problem with your license file. If you PM me your license serial number I can check it for you. You can find the serial number in Help->about.
Re: New computer
No gcode looks fine to look at however there is no display of file and when i run the processor it does not show the warnings. If i process on my old windows 7 machine all is good. I did however find what what caused the nested comment, i had saved the file name in brackets, resaved without and that fixed that. Will have to get my licence number tomorrow.
