Decimal mark problem
I have problems with the decimal marks. My system language is set to sv_SE but SheetCam using en_GB according to the debug log. Every text box expecting a float value writes the preset value with a comma but when pressing OK it says it's unable to parse. I have to replace all commas with points before clicking OK. If changing my system language to english it works.
Re: Decimal mark problem
Is it just me having this problem?
In SheetCam go to Options->application options->language and select 'System default language'. That should solve the problem.
When I changed to System default the problem remained with this lines in the log:
Application started
21:43:10: System language is Swedish (sv_SE)
21:43:10: Currently selected language is System default language
21:43:10: Unable to determine current language.
But when I changed back to english it suddenly worked. It uses decimal points and thats fine for me as long it's consistently.
Application started
