Hi,
I am getting the following message on startup ( Axis are not refed to normal condition)
and do not understand how to solve it?
Can anyone help?
Regards
Roy
Error message on startup
Re: Error message on startup
That looks like a controller error message. What controller are you using? It sounds like you need to reference the machine before starting a cut.
Hi Les
Strange thing this, I am using the Mach3 processer, It happens every time
I load the program and I have changed no settings. I had a crash a couple of days
age caused by a spike (I think) It all started after that.
I got a little fed up of trying to solve this and reluctantly deleted Mach3 and
reinstalled. Since then no more problems. I have installed a spike arrester so
hopefully it should be ok now.
Many thanks for your help
Regards
Roy
Regards
Roy
