Hi
I am using Scanything with Mach3 and PokeysCnc57. I am having problems when trying to jog in the X axis. It would seem that I can only travel in one direction and only the master(not slave) motor is turning. All movement on the X axis is always in one direction no matter the direction of the request.
Any suggestions please?
Scanything and Pokeys
Re: Scanything and Pokeys
Hi , just instaled Scanything on my Pokey plasma now , mach3, and have the same problem , how did you fix it ?
Unfortunately I did not fix it as the two softwares are not compatible. The Scanything needs to talk to internal functions of Mach that are no longer available due to the Pokeys DLL shielding those for it's own control
