tiny wierd triangles created on import
Marty
Post by Marty »
I have been using Sheet cam for a few years and love it....."all of a sudden" "for no apparent reason" LOL after importing dxf files and creating lead ins, each object has 3 start points created. The correct one, plus 2 little tiny triangles Files are attached to see what I mean. I am 99.999% sure it is not being exported from Corel X8. Any help to avoid the goblins is appreciated I never had this happen before
Marty
lucy and frank triangle error .job
(103.75 KiB) Downloaded 77 times
lucy and frank.tap
(25.1 KiB) Downloaded 79 times
lucy and frank triangle error .dxf
(315.35 KiB) Downloaded 87 times
Re: tiny wierd triangles created on import
I don't know what those triangles are but they are definitley in the dxf file.
Marty
Post by Marty »
ok thanks Les I will put Coreldraw under the microscope and run some export tests
Appreciate the look see...possibly Corel is leaving some artifacts after copy/paste /trim of objects
Marty
