post does not start in V6.1.5.3
I would like to cut two simple letters "HP" see attached file. (with the drag knife plugin)
In V6.1.5.3 the post does not start. It seems to be something wrong with the "P"
The same file opend in V6.025 works fine. The file can be generated without problems.
Maybe someone can tell me what´s goìng wrong ?
- HP_Linie.dxf
- (62.49 KiB) Downloaded 121 times
Re: post does not start in V6.1.5.3
Could you post a copy of the job file (file->save job) with the cuts set up.
The job can not be saved in V6.1.5.3. Sheetcam hangs up completely.
The original File is from inkscape 0922, see the file attached.
Open this in sheetcam V6.1.5.3 and see what happens.
This morning I opend the svg file in V6.0.25 without any problems.
- HPL_Wettbewerb_KZ.svg
- (4.92 KiB) Downloaded 139 times
now I think that the V6.1.5.3 has a problem with svg files.
I created a new one, see attached to this mail.
V6.1.5.3 can not handle the file correctly. V 6.025 has no problems .
- Nr.svg
- (8.63 KiB) Downloaded 168 times
Re: post does not start in V6.1.5.3 (and now with DXF files)
and now V6153 has problems with dxf files. It reports errors, but the file is clean.
With V6.025 the file is handeld correct.
- adap_marcus.dxf
- (606 KiB) Downloaded 113 times
At what point are you having problems? I loaded all of those drawings and they look correct.
Could you give me a support file. Go to Help->create a support file and click on the 'create file'. Email the file to me or post it here on the forum.
you have a pm with the support file
This is really odd. Using 6.1.53 with your license, settings and job file it worked correctly, generating the tool paths in under a second. I have no idea why you are gettings those errors. Al I can think of is that you had a failed update and some files were not installed correctly. It is pretty rare for that to happen though. Uninstall SheetCam and reinstall it. You won't lose your settings.
Hello Les,
well, I uninstalled V6.1.5.3 as you told me.
Now this version is running !
My virus program blocked the download. There is no reputation info for the download file. I had to agree to download it.
(for your information)
Many thanks
Regards
Hans-Peter
![Smile :-)](./images/smilies/icon_smile.gif)
Many thanks
Regards
Hans-Peter
What anti virus are you using? The download is digitally signed so it should not be blocked.
I use the norton antivirus (Telekom edition)
see the result attached
Dateiname: SheetCam TNG Development setup V6.1.53.exe
Vollständiger Pfad: C:\Users\herta\Downloads\SheetCam TNG Development setup V6.1.53.exe
_________________________
Entwickler
Stable Design
Version
Nicht verfügbar
Identifiziert
20.03.2018 um 17:44:34
Zuletzt genutzt
Nicht verfügbar
Startobjekt
Nein
____________________________
Sehr wenige Benutzer
Weniger als 5 Benutzer in der Norton Community haben diese Datei verwendet.
Sehr neu
Diese Datei wurde vor weniger als 1 Woche veröffentlicht.
Unerprobt
Es gibt nicht genügend Informationen über diese Datei, um sie zu empfehlen.
Quelldatei:
sheetcam tng development setup v6.1.53.exe
after first download the virus scanner moved the file to quarantine
Dateiabdruck - SHA:
868ca88aa8cb54c3644a4d138b17e36b203ea457db64b4de897eff6b974fd63a
Dateiabdruck - MD5:
f96988f1b34f517e209b38762e85345c
Entwickler
Stable Design
Version
Nicht verfügbar
Identifiziert
Zuletzt genutzt
Nicht verfügbar
Startobjekt
Nein
Sehr neu
Unerprobt
Quelldatei:
Dateiabdruck - SHA:
Dateiabdruck - MD5:
