G code issue
kbenz
G code issue
Post by kbenz »
I don't know if I changed a setting or what? when I run a new code on my plasma table (mach) the torch touches off, pierces and goes to the .060 cut height. but it stays locked there no matter the volts. If I run an older code it runs fine though.
Is there a setting somewhere?
Have you changed your post processor? If you look at the old g-code it will probably show the name of the post processor used in the first few lines. Is this the same as the new code?
kbenz
Post by kbenz »
just checked, it is the same MP1000-THC post processor
kbenz
Post by kbenz »
what is a GO4 PO.4 and GO4 PO.5? this is inconsistant
kbenz
Post by kbenz »
I see now the GO4 is a dwell
I changed my lead ins and outs from tangent(which I just started using) to arc and it ran fine??
The only other thing I can think of is possibly an issue with cutting rules do you use rules?
kbenz
Post by kbenz »
Les Newell wrote:The only other thing I can think of is possibly an issue with cutting rules do you use rules?
No rules
