Re: rotary plasma set up
kohlgren@gmail.com [sh...
Post by kohlgren@gmail.com [sh... »
there is a rotary plasma post processor in sheetcam and a rotary mach program (separate from mach3). there should be round and square post in sheetcam, i only use round in a 3 jaw chuck. tell us your setup: table and programs. the cad is 2d drawn flat.
mach3 has a new tube cutting program called pipefit too, never used it but should get into it soon. for tube copes look at Cobra Torch - TubeNotcherPlus you'll need to unblock it from java as it is setup in an old version of java. it will output into dxf for import to a cad program. also check out metalgeek.com
Cobra Torch - TubeNotcherPlus This program is an enhancement of the tubemiter program found on the web. This enables a user to notch a tube to fit tightly to a base tube at any desired angle. User inputs tube dimensions, angular orientation the the program generates a full size paper template. Additionally thi...
View on www.cobratorch.net
Preview by Yahoo
__._,_.___
Posted by: kohlgren@gmail.com
Visit Your Group
__,_._,___
Marius Liebenberg mari...
Post by Marius Liebenberg mari... »
I tried to run it but as you mention the Java issue comes up. How do you unblock it from java?
Regards
Marius
http://www.cnccontrol.co.za
http://www.mastercut.co.za
On Thursday, January 15, 2015 9:12 PM, "kohlgren@gmail.com [sheetcam]" <sheetcam@yahoogroups.com> wrote:
Preview by Yahoo
#yiv0080382568 #yiv0080382568 -- #yiv0080382568ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #yiv0080382568 #yiv0080382568ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv0080382568 #yiv0080382568ygrp-mkp #yiv0080382568hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv0080382568 #yiv0080382568ygrp-mkp #yiv0080382568ads { margin-bottom:10px;} #yiv0080382568 #yiv0080382568ygrp-mkp .yiv0080382568ad { padding:0 0;} #yiv0080382568 #yiv0080382568ygrp-mkp .yiv0080382568ad p { margin:0;} #yiv0080382568 #yiv0080382568ygrp-mkp .yiv0080382568ad a { color:#0000ff;text-decoration:none;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ygrp-lc { font-family:Arial;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ygrp-lc #yiv0080382568hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ygrp-lc .yiv0080382568ad { margin-bottom:10px;padding:0 0;} #yiv0080382568 #yiv0080382568actions { font-family:Verdana;font-size:11px;padding:10px 0;} #yiv0080382568 #yiv0080382568activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #yiv0080382568 #yiv0080382568activity span { font-weight:700;} #yiv0080382568 #yiv0080382568activity span:first-child { text-transform:uppercase;} #yiv0080382568 #yiv0080382568activity span a { color:#5085b6;text-decoration:none;} #yiv0080382568 #yiv0080382568activity span span { color:#ff7900;} #yiv0080382568 #yiv0080382568activity span .yiv0080382568underline { text-decoration:underline;} #yiv0080382568 .yiv0080382568attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #yiv0080382568 .yiv0080382568attach div a { text-decoration:none;} #yiv0080382568 .yiv0080382568attach img { border:none;padding-right:5px;} #yiv0080382568 .yiv0080382568attach label { display:block;margin-bottom:5px;} #yiv0080382568 .yiv0080382568attach label a { text-decoration:none;} #yiv0080382568 blockquote { margin:0 0 0 4px;} #yiv0080382568 .yiv0080382568bold { font-family:Arial;font-size:13px;font-weight:700;} #yiv0080382568 .yiv0080382568bold a { text-decoration:none;} #yiv0080382568 dd.yiv0080382568last p a { font-family:Verdana;font-weight:700;} #yiv0080382568 dd.yiv0080382568last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #yiv0080382568 dd.yiv0080382568last p span.yiv0080382568yshortcuts { margin-right:0;} #yiv0080382568 div.yiv0080382568attach-table div div a { text-decoration:none;} #yiv0080382568 div.yiv0080382568attach-table { width:400px;} #yiv0080382568 div.yiv0080382568file-title a, #yiv0080382568 div.yiv0080382568file-title a:active, #yiv0080382568 div.yiv0080382568file-title a:hover, #yiv0080382568 div.yiv0080382568file-title a:visited { text-decoration:none;} #yiv0080382568 div.yiv0080382568photo-title a, #yiv0080382568 div.yiv0080382568photo-title a:active, #yiv0080382568 div.yiv0080382568photo-title a:hover, #yiv0080382568 div.yiv0080382568photo-title a:visited { text-decoration:none;} #yiv0080382568 div#yiv0080382568ygrp-mlmsg #yiv0080382568ygrp-msg p a span.yiv0080382568yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #yiv0080382568 .yiv0080382568green { color:#628c2a;} #yiv0080382568 .yiv0080382568MsoNormal { margin:0 0 0 0;} #yiv0080382568 o { font-size:0;} #yiv0080382568 #yiv0080382568photos div { float:left;width:72px;} #yiv0080382568 #yiv0080382568photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv0080382568 #yiv0080382568photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv0080382568 #yiv0080382568reco-category { font-size:77%;} #yiv0080382568 #yiv0080382568reco-desc { font-size:77%;} #yiv0080382568 .yiv0080382568replbq { margin:4px;} #yiv0080382568 #yiv0080382568ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv0080382568 #yiv0080382568ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #yiv0080382568 #yiv0080382568ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv0080382568 #yiv0080382568ygrp-mlmsg select, #yiv0080382568 input, #yiv0080382568 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #yiv0080382568 #yiv0080382568ygrp-mlmsg pre, #yiv0080382568 code { font:115% monospace;} #yiv0080382568 #yiv0080382568ygrp-mlmsg * { line-height:1.22em;} #yiv0080382568 #yiv0080382568ygrp-mlmsg #yiv0080382568logo { padding-bottom:10px;} #yiv0080382568 #yiv0080382568ygrp-msg p a { font-family:Verdana;} #yiv0080382568 #yiv0080382568ygrp-msg p#yiv0080382568attach-count span { color:#1E66AE;font-weight:700;} #yiv0080382568 #yiv0080382568ygrp-reco #yiv0080382568reco-head { color:#ff7900;font-weight:700;} #yiv0080382568 #yiv0080382568ygrp-reco { margin-bottom:20px;padding:0px;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ov li a { font-size:130%;text-decoration:none;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv0080382568 #yiv0080382568ygrp-sponsor #yiv0080382568ov ul { margin:0;padding:0 0 0 8px;} #yiv0080382568 #yiv0080382568ygrp-text { font-family:Georgia;} #yiv0080382568 #yiv0080382568ygrp-text p { margin:0 0 1em 0;} #yiv0080382568 #yiv0080382568ygrp-text tt { font-size:120%;} #yiv0080382568 #yiv0080382568ygrp-vital ul li:last-child { border-right:none !important; } #yiv0080382568
__._,_.___
Posted by: Marius Liebenberg <marius.liebenberg@yahoo.com>
Visit Your Group
__,_._,___
Emanuel gamhoover@yaho...
Post by Emanuel gamhoover@yaho... »
I'm using mach3 but it didn't seem to be compatible with NcStudio I think someone could edit the pp could you help me if I send you what ever you need
Emanuel Hoover 5195690667
On Jan 15, 2015, at 2:12 PM, kohlgren@gmail.com (kohlgren@gmail.com) [sheetcam] <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
Preview by Yahoo
__._,_.___
Posted by: Emanuel <gamhoover@yahoo.com>
Visit Your Group
__,_._,___
in the windows menu open ''configure java'' go to security tab, enter http://cobratorch.net into the exceptions list
still haven't told us anything about your machine. cad, cam and machine programs, this helps you not me
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
It was not my question or problem. I just had a look at what you suggested but could not load it. Hence my question on the java problem :)
I think it was Emanuel that asked for the help.
Regards
Marius
On Friday, January 16, 2015 10:15 PM, "kohlgren@gmail.com [sheetcam]" <sheetcam@yahoogroups.com> wrote:
in the windows menu open ''configure java'' go to security tab, enter http://cobratorch.net into the exceptions list still haven't told us anything about your machine. cad, cam and machine programs, this helps you not me
#yiv9240787402 #yiv9240787402 -- #yiv9240787402ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #yiv9240787402 #yiv9240787402ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv9240787402 #yiv9240787402ygrp-mkp #yiv9240787402hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv9240787402 #yiv9240787402ygrp-mkp #yiv9240787402ads { margin-bottom:10px;} #yiv9240787402 #yiv9240787402ygrp-mkp .yiv9240787402ad { padding:0 0;} #yiv9240787402 #yiv9240787402ygrp-mkp .yiv9240787402ad p { margin:0;} #yiv9240787402 #yiv9240787402ygrp-mkp .yiv9240787402ad a { color:#0000ff;text-decoration:none;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ygrp-lc { font-family:Arial;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ygrp-lc #yiv9240787402hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ygrp-lc .yiv9240787402ad { margin-bottom:10px;padding:0 0;} #yiv9240787402 #yiv9240787402actions { font-family:Verdana;font-size:11px;padding:10px 0;} #yiv9240787402 #yiv9240787402activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #yiv9240787402 #yiv9240787402activity span { font-weight:700;} #yiv9240787402 #yiv9240787402activity span:first-child { text-transform:uppercase;} #yiv9240787402 #yiv9240787402activity span a { color:#5085b6;text-decoration:none;} #yiv9240787402 #yiv9240787402activity span span { color:#ff7900;} #yiv9240787402 #yiv9240787402activity span .yiv9240787402underline { text-decoration:underline;} #yiv9240787402 .yiv9240787402attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #yiv9240787402 .yiv9240787402attach div a { text-decoration:none;} #yiv9240787402 .yiv9240787402attach img { border:none;padding-right:5px;} #yiv9240787402 .yiv9240787402attach label { display:block;margin-bottom:5px;} #yiv9240787402 .yiv9240787402attach label a { text-decoration:none;} #yiv9240787402 blockquote { margin:0 0 0 4px;} #yiv9240787402 .yiv9240787402bold { font-family:Arial;font-size:13px;font-weight:700;} #yiv9240787402 .yiv9240787402bold a { text-decoration:none;} #yiv9240787402 dd.yiv9240787402last p a { font-family:Verdana;font-weight:700;} #yiv9240787402 dd.yiv9240787402last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #yiv9240787402 dd.yiv9240787402last p span.yiv9240787402yshortcuts { margin-right:0;} #yiv9240787402 div.yiv9240787402attach-table div div a { text-decoration:none;} #yiv9240787402 div.yiv9240787402attach-table { width:400px;} #yiv9240787402 div.yiv9240787402file-title a, #yiv9240787402 div.yiv9240787402file-title a:active, #yiv9240787402 div.yiv9240787402file-title a:hover, #yiv9240787402 div.yiv9240787402file-title a:visited { text-decoration:none;} #yiv9240787402 div.yiv9240787402photo-title a, #yiv9240787402 div.yiv9240787402photo-title a:active, #yiv9240787402 div.yiv9240787402photo-title a:hover, #yiv9240787402 div.yiv9240787402photo-title a:visited { text-decoration:none;} #yiv9240787402 div#yiv9240787402ygrp-mlmsg #yiv9240787402ygrp-msg p a span.yiv9240787402yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #yiv9240787402 .yiv9240787402green { color:#628c2a;} #yiv9240787402 .yiv9240787402MsoNormal { margin:0 0 0 0;} #yiv9240787402 o { font-size:0;} #yiv9240787402 #yiv9240787402photos div { float:left;width:72px;} #yiv9240787402 #yiv9240787402photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv9240787402 #yiv9240787402photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv9240787402 #yiv9240787402reco-category { font-size:77%;} #yiv9240787402 #yiv9240787402reco-desc { font-size:77%;} #yiv9240787402 .yiv9240787402replbq { margin:4px;} #yiv9240787402 #yiv9240787402ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv9240787402 #yiv9240787402ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #yiv9240787402 #yiv9240787402ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv9240787402 #yiv9240787402ygrp-mlmsg select, #yiv9240787402 input, #yiv9240787402 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #yiv9240787402 #yiv9240787402ygrp-mlmsg pre, #yiv9240787402 code { font:115% monospace;} #yiv9240787402 #yiv9240787402ygrp-mlmsg * { line-height:1.22em;} #yiv9240787402 #yiv9240787402ygrp-mlmsg #yiv9240787402logo { padding-bottom:10px;} #yiv9240787402 #yiv9240787402ygrp-msg p a { font-family:Verdana;} #yiv9240787402 #yiv9240787402ygrp-msg p#yiv9240787402attach-count span { color:#1E66AE;font-weight:700;} #yiv9240787402 #yiv9240787402ygrp-reco #yiv9240787402reco-head { color:#ff7900;font-weight:700;} #yiv9240787402 #yiv9240787402ygrp-reco { margin-bottom:20px;padding:0px;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ov li a { font-size:130%;text-decoration:none;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv9240787402 #yiv9240787402ygrp-sponsor #yiv9240787402ov ul { margin:0;padding:0 0 0 8px;} #yiv9240787402 #yiv9240787402ygrp-text { font-family:Georgia;} #yiv9240787402 #yiv9240787402ygrp-text p { margin:0 0 1em 0;} #yiv9240787402 #yiv9240787402ygrp-text tt { font-size:120%;} #yiv9240787402 #yiv9240787402ygrp-vital ul li:last-child { border-right:none !important; } #yiv9240787402
__._,_.___
Visit Your Group
__,_._,___
