Hello!
I'm getting a bit tired of toolchanges but can't afford a ATC machine.
A dual head machine is quite easy and share y and x axis but have separate Z axis.
Can I program Sheetcam to use tool 1 with spindle 1 and tool 2 with spindle 2? That would solve almost all my toolchanges!
Hoping to hear from you.
Dual head function sheetcam
Yes you can. Use the Mach3 2 heads post processor. You will have to edit the post. Near the start of the file you should find a bunch of settings to tell the post how your machine is configured.
The way it works is that tools numbered 1-99 will be the first head and tools 100+ will be the second head. Note that when using the second head the coordinates in Mach3 will look wrong because SheetCam will have added the second head offsets.
