Les Newell les.newell@...
Post by Les Newell les.newell@... »
Oops, my bad. I started with a post that uses Z0 as the top of the table. This version uses Z0 as the top of the work.
Brian, can you fudge the feed rate for now, just to make sure the rest of the code works as expected.
On 12/06/2014 01:55, Brian Lamb blamb11@cox.net (blamb11@cox.net) [sheetcam] wrote:
Glad to see I wasn’t the only one with problems. It might be easier to copy the tapping section of the post into the existing post you are using.
Brian Lamb
__._,_.___
View attachments on the web Posted by: Les Newell <les.newell@fastmail.co.uk>
Visit Your Group
__,_._,___
Mach3-tap-dwell.scpost
(7.92 KiB) Downloaded 192 times
