Hello, i just installed the DCC upgrade screen on mach, everything works.
In sheetcam, i changed to post : mp3000 dthcii-dcc-hyt+scriber
It kept all my tools and parameters, and set 49 as default preset volts.
But when i try to change volts, update operation, when i close the tool window, then reopen it, the volts still show 49.
When loading the g-code in mach, on line 0150, i read: (no preset volts)
But i assume its the same issue.
I have sheetcam dev.5.1.35
thanks.
