mach3 plugin
rikduk
mach3 plugin
Post by rikduk »
Thanks for fixing the mach3 plugin, it now recognizes my mach.
But, i must be missing a step, cause when i post process, it doesnt load in mach...dont flame me please...
the plugin is enabled
And what is the new button M that"notifies mach when post process is complete" ?
if i open it, all the fields are gray, i cant do nothing.
Must be something simple im missing, i just dont know what.
When you go to Options->plugin options->mach does it say a compatible version of Mach3 was detected?
In the plugins menu is 'Enable Mach3' turned on? Do you see the Mach3 plugin in SheetCam. It should have X,Y,Z DROs and a number of other buttons. Are the buttons greyed out even if Mach is running?
Run Mach and go to Config->Config plugins and make sure the 'SheetCamRemote' plugin is enabled.
rikduk
Post by rikduk »
DUH!! It wasnt enabled in mach...i knew it was simple!
Just need to add arc volts to toolsets with DCC, and voilà!
Post, and everything is ready in mach :lol:
