new angle threshold feature not working
I'm working with a lot of inside offsets on angles greater than 100 degrees. For outside offsets this is not a problem because the corner loop option is always there. Not the case for inside cuts...nor does the new angle threshold upgrade appear to be doing anything. Am I using it incorrectly? I have tried every combination of settings I can think of. Attached is a pic of some 110 and 120 degree angles that are giving me radius corners where the program calls out for zero radius.
- angle.JPG (95.47 KiB) Viewed 1956 times
