Reverse Cut Side
Reverse Cut Side
Why cant I get it to reverse cut side? I am sure I have done it before. I switch to No Offset and then click to show the starting points and right click on reverse cut side but it only changes that one starting point. I had 50 different starting points and had to change each one individually. I am sure I have done this before and when you reversed one starting point it reversed them all. Thank you in advance.
The issue I am having is when using outside offset is that I have two tool paths that get close together and then widen out. It will actually stop cutting where the paths get too close together and then start back up where they come apart. If I change to no offset it solves the problem but reverses cut side on all my lead ins. So I should just make the cutter diameter smaller and continue to use outside offset? thank you
