Drill a hole in center of pocket
if I select some areas for pocket milling and if I'd like to drill a hole in the center of each pocket (i.e. where the pocket cycle starts) to make it easier for the following tool to work, is there a function or a variable to support me for this ?
If not it would be a nice feature to add :
a 'Drill a hole in the center' - cycle ?
Richard
Richard
The problem is mainly in how to implement it. Operations are independent of each other so I can't create a drilling operation that depends on another operation's cut starts. The other option is to add drilling options to the pocketing dialog but that adds a lot of extra confusing options that few people will need.
Pete,
MLCS has obviously great tools but s&h to Germany for example for #202
is as follows :
First-Class Mail International ($17.64)
Priority Mail International ($31.05)
Express Mail International ($38.00)
UPS Worldwide Expedited (SM) ($91.00)
UPS Worldwide Saver (SM) ($95.12)
UPS Worldwide Express (SM) ($98.87)
That's pretty too much for a hobbiest like me
Richard
is as follows :
Richard
My idea was actually to ' collect ' some positions to use for drilling in connection with G81/G80 and if I do this I will know that the drilling operation will work with the same parameters at every position. If I need different values i.e. for the depth I will have to add them manually in each line .
And for for use as drilling coordinates the G00 in each line must be removed, too (manually of course)
The same way I could add between each move a subprogram call to mill something like a pattern at this position.
I know those capabilities from the control I use day by day at work (Heidenhain TNC 430).
Anyway I can use it the way it works now
Richard
Richard
