V4.1.16 released
New releases and important announcements will be posted here. This is for announcements only. Please use the new features or problems forums to discuss new releases.
V4.1.16 released
Post by Les Newell » Fri Feb 09, 2007 4:45 pm
Hi all,
I have just uploaded V4.1.16 to www.sheetcam.com. This version has the following changes:
Fixed: Cut estimate window layout wrong when using a display setting of 120DPI
Changed: Job filename defaults to first drawing loaded if it is currently 'untitled'
Fixed: In tool setup dialog if you change from tap to mill, ramp angle is displayed as 'underfeed'
Changed: The 100 tool limit is now removed. You can now have a virtually unlimited number of tools.
Changed: Tool and process lists now update as you drag the scroll bar
Changed: Plasma loop size slider now allows bigger loops
Note that removing the tool limit involved a lot of changes to SheetCam. If you spot any problems then please let me know.
