V4.1.8 released
New releases and important announcements will be posted here. This is for announcements only. Please use the new features or problems forums to discuss new releases.
V4.1.8 released
Hi all,
I have just uploaded V4.1.8 to www.sheetcam.com. This release has lots of changes:
Fixed: Coolant and other process variables getting corrupted
Fixed: Layer names with leading spaces causing problems when reloading a job
Fixed: Tool too deep and tool too short warning status not always updated
Added: Warning if tool is missing from tool table
Added: Updated French translation (Thanks Thierry!)
Fixed: Changing tool number does not always update paths
Changed: Right click on process list selects process before popping up menu
Changed: Right click on tool list selects tool before popping up menu
Changed: process/tool popup now appears to the right of the list
Added: Tool hint only shows if the whole name is not visible
Fixed: incorrect 'tool may not be able to cut this deep' error
Added: Option to disable duplicate line removal (Options->System parameters)
