V4.1.8 released
V4.1.8 released
Post by Les Newell » Fri Dec 15, 2006 7:57 pm
Hi all,
I have just uploaded V4.1.8 to www.sheetcam.com. This release has lots of changes:
Fixed: Coolant and other process variables getting corrupted
Fixed: Layer names with leading spaces causing problems when reloading a job
Fixed: Tool too deep and tool too short warning status not always updated
Added: Warning if tool is missing from tool table
Added: Updated French translation (Thanks Thierry!)
Fixed: Changing tool number does not always update paths
Changed: Right click on process list selects process before popping up menu
Changed: Right click on tool list selects tool before popping up menu
Changed: process/tool popup now appears to the right of the list
Added: Tool hint only shows if the whole name is not visible
Fixed: incorrect 'tool may not be able to cut this deep' error
Added: Option to disable duplicate line removal (Options->System parameters)
