V4.1.3 released
New releases and important announcements will be posted here. This is for announcements only. Please use the new features or problems forums to discuss new releases.
V4.1.3 released
Hi all,
I have just uploaded V4.1.3 to www.sheetcam.com. This release contains the following changes:
Fixed: DXF circles sometimes mirrored about X (Z extrusion ignored)
Fixed: New tap process visible when in plasma only mode
Fixed: New drill process not visible when in plasma only mode
Fixed: Incorrect outlines displayed when switching between parts
Fixed: Part names defaulting to 'Untitled' when reloading a job
Added: Cutting rules in 'Cut path' tab
The cutting rules replace 'Ignore inside/outside rules'. You now have 3 options:
All inside first - All inside shapes are cut first then all outside shapes.
Shortest path - All shapes are cut with the shortest slew between them. All inside/outside rules are ignored.
Keep parts together - If your drawing contains multiple nested parts then each part is cut out completely before moving on to the next part. Each part is cut from the inside out.
