Small feature re. Material thickness
Posted: Fri Nov 06, 2020 8:36 am
Hi,
I humbly ask to consider addition of data into the auto-generated name of every created operation in the Operations block of the program main window.
Now it only shows Type of the operation, Layer, Tool Details and Depth of machining. Material thickness would be a very valuable addition.
To check the current Material thickness one has to go to the Operation Properties Window which is time-consuming when working with multiple job files... Please add Material info into the name of an operation.
Also, it is inconvenient to split an order (a "job", actually) containing parts of more than one thickness into separate job files (because Material thickness Setting is effective through all parts in the job file)… I think that or similar kind of request had been posted before, I am sorry if I raise a question that was dealt with before...
Thank you.
Thank you.
