Remove pierce plunge & return to rapid.
turnerandtaylor
Post by turnerandtaylor » Thu Mar 01, 2018 9:53 pm
Backstory:
We've been using Sheetcam on our in-house built cnc plasma for the last year and it's worked without issue. We now need to modify our post (attached), but I haven't been able to figure out how to omit the feedrate plunge that happens after piercing, or omit the rapid move up to the safeZ after the cut is done.
I need this:
N0230 M03
N0240 G01 X5.2194 Y0.3387 Z0.0600 F100
N0250 G02 X5.2194 Y0.3387 I0.0000 J0.1613 F63.0
N0260 M05
N0270 G00 Z0.2500
to become this:
N0230 M03
N0260 M05
Is this something that can be done in the post, or is this integral to Sheetcam? And if so, how can I turn these off?
Josh Taylor
Turner & Taylor Metal Works, Inc.
Re: Remove pierce plunge & return to rapid.
Post by Les Newell » Fri Mar 02, 2018 3:20 pm
Those moves are gaenerated from within SheetCam but they can be bypassed. Are you trying to remove the Z moves completely or do you just want to remove those specific moves?
turnerandtaylor
Post by turnerandtaylor » Fri Mar 02, 2018 5:36 pm
Thanks for responding. I need to remove those specific Z movements put in by Sheetcam as relates to the plunge & retract. In practice, that equates to all of them, however, I would prefer to omit them directly rather than search and delete all Z movements in the tap file for instance. How can those be bypassed?
Josh Taylor
Post by Les Newell » Fri Mar 02, 2018 8:32 pm
Go to Options->Machine->post processor and click on the 'Edit post' button.
Look for lines like this:
post.ModalNumber (" Z", (endZ + toolOffset) * scale, "0.000")
and delete them. This will remove all Z moves. Most posts have 3 of these lines. Just doing this will cause the post to sometimes output a line that is just G00 or G01 with no coordinates. If that is a problem try adding this code to the beginning of function OnRapid() and function OnMove():
   if (math.hypot(endX - currentX, endY - currentY) < 0.01) then return end
turnerandtaylor
Post by turnerandtaylor » Tue Mar 13, 2018 4:40 pm
Thank you. This all works perfectly. I can't foresee needing to actually post Z movements, but if it comes up, I'll post back here to see if there is a fix. I'll also upload my post-processor in case anybody else searches for the same thing.
Thanks again,
Josh Taylor
