Davek0974
Posts: 286 Joined: Sat Feb 01, 2014 2:07 pm
Post
by Davek0974 » Fri Aug 15, 2014 6:39 am
I am using sheetcam on a small plasma table and already have 20+ tools in the default box.
Is there a way we could have maybe a tabbed toolbox that we can easily add tabs at will, give them a name and drop tools into??
That way we could group tools by metal thickness or torch tip type etc.
Davek0974 on Fri Aug 15, 2014 2:18 pm, edited 1 time in total.
Posts: 3665 Joined: Thu May 11, 2006 8:12 pm
Post
by Les Newell » Fri Aug 15, 2014 10:20 am
That is an interesting idea. I'll look into it.
Davek0974
Post
by Davek0974 » Fri Aug 15, 2014 2:17 pm
Brilliant, I think it would be a worthwhile addition.
dave
SeanP
Posts: 217 Joined: Wed Oct 23, 2013 9:50 am
Post
by SeanP » Sat Aug 16, 2014 10:11 pm
Mine is't as tidy as it could be but I found it does help if you get the tool numbering spaced out more, ie: say I want to add another tool for 6mm I would number it 61 and that adds it in the right order.
aeviaanah
Posts: 6 Joined: Thu Apr 23, 2015 11:56 pm
Post
by aeviaanah » Wed Apr 29, 2015 12:45 am
Sean P. How do you create a tool list like this?
Do you create a bunch of tools and save as a template? Load that template prior to starting a job?
SeanP
Post
by SeanP » Wed Apr 29, 2015 8:10 am
aeviaanah wrote: Sean P. How do you create a tool list like this?
It's only a screenshot from the tools table editor.
It's just made up from adding tools using that numbering order.
Sean
Post
by Les Newell » Wed Apr 29, 2015 11:16 am
You can save tool sets for later use using 'File->save toolset as'.
Vmax549
Posts: 641 Joined: Mon Nov 09, 2009 5:55 pm
Post
by Vmax549 » Tue May 05, 2015 4:51 pm
I have been playing with Plugins and created a master tool set function. You can also sort by tool Number OR Diameter.
ChrisAttebery
Post
by ChrisAttebery » Tue May 05, 2015 6:08 pm
Vmax,
That sounds interesting. Care to share it with us?
Chris
Vmax549
Post
by Vmax549 » Tue May 05, 2015 10:15 pm
Not a problem BUT I need to wait for Les to fix a couple of things first in Scam. Hopefully next update.
(;-) TP
