Pause the cutting operation before every cut
Posted: Mon Jan 27, 2020 7:10 pm
by drafting@gsb
I am using sheet cam for plasma Rotary cutting, Can anyone please tell me how to edit the post processor to add "Pause" before every cut! What is the code and where to insert the code?
Re: Pause the cutting operation before every cut
Posted: Mon Jan 27, 2020 9:41 pm
by robertspark
Edit the post processor
you will find a section called "function OnPenDown()"
Add in a line which says "post.Text (" M0 (Paused >> Press Run) ")
and that should work for you {note, I don't known which cnc controller software you are using)
