Cutmaster 60i
General chat and non SheetCam related discussion
pgilley
Cutmaster 60i
Post by pgilley » Fri May 17, 2019 9:38 pm
Anyone using the Esab Cutmaster 60i on a plasma table ? I am using a Cutmaster 52 (Radnor version) and the duty cycle shuts down at times. Some cuts run about 20 minutes. Just wondering if my 1Torch on the 52 will work on the 60i ? I am using the 1Torch hand torch wired directly to the trigger switch and it works great with my cheap table. Just want to know that my wiring system will trigger the 60i. Sent this question to Esab and have not received a reply. I am positive that the 1Torch on my cutter will connect to the 60i. Checked with my welding supplier and made sure about the quick connect on both machines.
robertspark
Re: Cutmaster 60i
Post by robertspark » Mon May 20, 2019 9:37 am
I'd suggest that you ask on plasmaspider forum as it covers the broad application of "plasma" in all shapes and forms where as this is for "sheetcam" specifically.
https://www.plasmaspider.com/
{you'll get more passing traffic able to ask your question too}
Rob
