Linux version unuseable
aaron
Post by aaron »
Hi
Please help I need to use the linux version of Sheet cam. Can somebody tell me how to set up the machine and tool set.
Thankyou
WyoGreen
Re: Linux version unuseable
Post by WyoGreen »
Hi Aaron,
Be glad to help get you up and running. But we will need to know more about your system to do so. What plasma cutter, what controller, etc.. I assume that you have your version of Linux running, and have Sheetcam loaded and running. Hopefully my answer to your other question got that issue resolved.
aaron
Post by aaron »
Am running sheetcam on Ubuntu 20.04. I have CNC Router controlled with linuxcnc. But it is sheetcam not displaying options dialogues properly which is my problem.
Aaron
WyoGreen
Post by WyoGreen »
Here is what I replied in the other thread:
I have found that if you go to Settings ->Appearance ->Style and change from Graybird to Numix, you'll be able to see the check boxes.
Please tell me how you do this. There is no settings tab in Sheetcam.
Aaron
The setting is in Linux. I use Xubuntu, so I go to the Whisker menu, (upper left screen corner) then to Settings ->Appearance ->Style
