I have a custom oxy/fuel table.
Equipment is.
G203v stepper drivers
TMC3in1 BOB with THC for future plasma torch
ESS smoothstepper
Mach 4
I need to know if there is a post processor already written that will handle oxy/fuel cutting?
I want the gcode to pause at each pierce and wait for the preheat. I will handle each pierce manually and then press resume.
Thanks.
Mach 4 post processor oxy/fuel
Re: Mach 4 post processor oxy/fuel
Go to Options->machine->post processor and select the 'Mach4 plasma' post. Now click on 'Edit post'. Around line 79 you will see this code:
Directly after it add this line
That will put in an optional stop. If you prefer you could use M0 instead of M1.
function OnPenDown()
if (preheat > 0.001) then
modaltext (" G00")
post.Text (" G04 P")
post.Number (preheat,"0.0##")
post.Eol()
post.Text(" M1\n")
