Hey Les,
ran a simulation on a mill part and the rapid to the part is not following the g-code. Code rapids G0 to X,Y position and then feeds down to cut height. Simulation is ramping down to cut height along the G0 rapid to location.
Mill simulation not following actual tool path
- Contact:
Re: Mill simulation not following actual tool path
Could you send me the job file.
- Contact:
Here you go
- Bread Stick Gauge Engrave.job
- (21.91 KiB) Downloaded 60 times
Thanks. Fixed for the next release.
Now that's what I call service. An hour from bug report to having the issue resolved. I don't know how you do it, Les. Kudos.
- Contact:
+1! Les is on top of it!Now that's what I call service. An hour from bug report to having the issue resolved. I don't know how you do it, Les. Kudos.
