Hello All,
I am attempting to use the rotary plasma plugin to cut some tubes on a custom machine I made with some fellow university students. The machine is controlled through Mach4 if it mattes.
For some reason, the lead-ins generated have a significantly slower surface speed. Is there a setting to adjust this somewhere? Alternatively is it common for the lead-ins to be slow? I would understand it would take a bit of time for the arc to pierce the material, but we are cutting 0.035" thick tube.
Cheers
