Update problem
Update problem
Hello
I am having various issues with the 7.1.1 update
When I run Sheetcam, the matrix does not appear in the window
It also doesn't let me run the post processor.
What is the problem ?
Re: Update problem
What do you mean with matrix?luis lopez wrote: ↑Mon Mar 08, 2021 10:19 am When I run Sheetcam, the matrix does not appear in the window
Re: Update problem
The machine does not appear to me and neither does the material
- 1.PNG (82.18 KiB) Viewed 4554 times
Re: Update problem
I have the same issue.
For a workaround: Click the button "Show machine and work" twice. (de-select and select again)
Re: Update problem
I just found the display problem. There should be an update in the next hour or so.
Luis, when you say it won't let you run the post processor, do you get an error message?
Re: Update problem
it does not give me any error message. I hit the icon to generate the post processor and it doesn't generate it
Re: Update problem
Do you have a post selected?
Re: Update problem
Could you PM or email me your license serial number. You can find it in Help->about.
Re: Update problem
Can you tell me your email?
