rotary axis setup in linuxcnc, do I need to use letters U, V or W in lieu of AB or C.
given it seems that ABC are fixed rotational axis and are not linear as sheetcam expects to see?
thanks
rotary axis linuxcnc
Re: rotary axis linuxcnc
The linear axis stipulation is mainly aimed at Mach3, which does some odd stuff when in rotary mode. In LinuxCNC just make sure you don't enable WRAPPED_ROTARY on your rotary axes.
Thanks Les,
Much appreciated as always for your time.
