It appears the latest Development version ignores the X radius for shape corners from Inkscape svg files. In the past, you could create shapes with just the X radius, just the Y radius, or both set and it would render fine in Sheetcam. Now it only works for the Y radius or both.
Is this intentional or a bug?
Rounded Corners Squared
Re: Rounded Corners Squared
That is a bug. Could you send me a sample svg file.
I found the problem. It will be fixed in the next release (due out in a day or so).
