Offsetting Open Paths for Rotary
cloudy
Post by cloudy »
I'm trying to generate tube cuts for the Rotary plugin. I input flattened CAD, with the horizontal paths removed (So sheetcam doesn't generate a lengthwise cut)
This means the path is open. I've enabled offset open paths - but no matter which side I choose the cut is on the inner (wrong) side (and indeed the leadins are inside the intended part... Any ideas?
Re: Offsetting Open Paths for Rotary
Move the start points to the other end of the lines. It should switch the cut side.
cloudy
Post by cloudy »
That was it! Thankyou :)
Been there, done that. Glad it worked for you.
