download file for older version sheetcam
Re: download file for older version sheetcam
Maybe you're in the wrong mode? Do you have the selection tool (arrow) on the toolbar selected? I know some modes lock certain things out.
after looking at similar issues on the forum, i'm starting to think it is a license issue.
because when adding a cutting operation everthing looks good.
is see the pierce points, green movement lines, ....
but when i post the file on the pc at my shop the code file is almost empty
and on my pc at home it won't even let me hit the post processor button....
could les maybe check my license file?
You could be right. Maybe try removing your license and see if you get short code to work. I think it's limited to like 180 lines.
oh sorry forget to make that clear.
it posts the code fine without the license file on either pc.
but indeed with a 180 line limit.
so then it would be most likely the license file being pirated?
Sounds like a good possibility.
You could email Les. Maybe he will see that before this thread. His email is his name at SheetCam dot com.
