hi
back in 2008-2011 i had a dynatorch and i was using sheetcam to process all my files (dxf, svg, etc.)
now i am trying to get back on the bicycle. i installed the baileigh starfire post processor, brought my dxf in to sheetcam, ran the post processor but all i am getting is
G92 X0 Y0
G40
G90
M02
what am i missing.
the dwf file is 45,306 lines.
(1st 15 lines)
0
SECTION
2
HEADER
9
$ACADVER
1
AC1021
9
$ACADMAINTVER
70
25
9
$DWGCODEPAGE
3
(last 7 lines)
RTVSPropertyOp27
70
1
0
ENDSEC
0
EOF
thanks in advance
baileigh starfire post no working???
Re: baileigh starfire post no working???
Did you create an operation?
I stepped again thru the entering setup part. Created the operation. But I am missing something. See my last post re: missing elements.
Thanks for ur suggestion. I will keep digging.
Usually when you don't get any moves in the code it's because you don't have an operation. There are no paths to output. If you have a valid operation, then I'm not sure why your post processor isn't outputting code.
