SVG Scaling Issue in Development V6.9.8
jone6881
Post by jone6881 »
I ran into an issue today after updating to Development V6.9.8 with the scale of SVG files. I was able to find an old installer for V6.9.6 and the problem does not exist in that version.
When I add a new part from a SVG that is 20"x20" it comes in larger in sheetcam. Can anyone else confirm they have this same issue?
Re: SVG Scaling Issue in Development V6.9.8
Could you let me have a copy of the drawing so I can run some tests.
There should be an update in the next hour or so.
jone6881
Post by jone6881 »
Thanks Les! What do you think about having the ability to roll back updates on the development version? I have no idea if that would be feasible and in this case I had an old installer I was able to use to go back a couple versions.
