SheetCam beta for the terminally brave
Re: SheetCam beta for the terminally brave
A new beta is up:
https://www.sheetcam.com/Downloads/akp3 ... V6.9.5.exe
Comments in rule code snippets are now output in g-code
Edit contours now allows you to move/copy contours to other parts.
Added option for square corners when milling/routing contours (cut path tab).
Changed: Operations window is now available in nesting mode. It is only disabled if multiple parts are selected.
If noone finds any major issues, this will become the next dev release.
I haven't used shortcuts before but I did try it now and I found two problems.Les Newell wrote: ↑Tue Nov 03, 2020 11:29 am Has anyone been playing with the keyboard shortcuts? I'm looking at adding some more default shortcuts so it would be useful to know what you are using.
The shortcut for post processing doesn't work. Not the default Ctrl+P and not if I change it to an other.
If I set the same shortcut on a second command SheetCam asks if I want to remove it from the old command. But it isn't visually removed from shortcut list until reopen preferences. And it still visible on the menu item until restart.
Great. Is it possible to do for action point code snippets too?Les Newell wrote: ↑Tue Nov 03, 2020 12:24 pm Comments in rule code snippets are now output in g-code
Hello To All
Well ,Try the new version 6.9.5 and installed fine. But at the time to close it, it froze and gave the message of internal error . Screen will flash with the message and after that it crash. Don't know if the report got send to Les or not.
Best Regards
Marco.
Best Regards
Marco.
I can't replicate that one. Could you create a support file (Help->create a support file) and send it to me.
Yes. That is a known problem. I can probably fix the shortcut list but the menus could be more tricky.If I set the same shortcut on a second command SheetCam asks if I want to remove it from the old command. But it isn't visually removed from shortcut list until reopen preferences. And it still visible on the menu item until restart.
I'll add that to the next release.Great. Is it possible to do for action point code snippets too?
Thanks for testing it. Does this happen every time?
Couldn't create a support file. The files list is empty. This works in the development version 6.1.74I can't replicate that one. Could you create a support file (Help->create a support file) and send it to me.
- Skärmavbild 2020-11-04 kl. 20.29.11.png (50.81 KiB) Viewed 8429 times
Here are my settings and my post. Don't know where the log file is.
- support.zip
- (10.67 KiB) Downloaded 54 times
Les Newell wrote: ↑Wed Nov 04, 2020 1:54 pmThanks for testing it. Does this happen every time?
Hello Les
Yes,opens fine but at closing get the internal error,and closes ,but no report is generated.
Here is the log from trying to create a support file
- sheetcam_log.txt
- (5.66 KiB) Downloaded 55 times
How are you running SheetCam on your Mac? Looking at the logs, there seems to be somethign odd going on with the way temporary files are handled. I also suspect the keyboard shortcuts issues are also Mac related.
I'm using Wine but not WineBottler. I will try to investigate further to night. The support file command works in the developer version but not in beta. Not in a clean install with removed settings folder either.
I haven't changed anything in the support file code so I guess there is something different in the way wxWidgets3 handles this. I will investigate further.
