Postprocessor Sheetcam for Flexicam stealth 1530
Posted: Tue Jul 14, 2020 8:46 pm
I need a postprocessor Sheetcam for my Flexicam stealth 1530.
This postprocessor from artcam does not work for Sheetcam. Can someone give any advice how to fix?
; FlexiCAM configuration file
; History
; Who When What
; JON 26/12/01 Written
DESCRIPTION = "Flexicam (mm) (*.GC)"
FILE_EXTENSION = "GC"
UNITS = mm
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.3]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3|-1]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3|-1]
; Set feed rate used for rapid moves 1000in/min
RAPID_FEED_RATE = 1000
; Set up program header
START = "%"
START = "G90"
START = "G71"
START = "G40"
START = "[S]"
START = "T[T]"
START = "G0 [XH] [YH] [F]"
START = " [ZH]"
; Program moves
RAPID_RATE_MOVE = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[X] [Y] [Z]"
; End of file
END = "G0 [ZH] [F]"
END = "G0 X0 Y0"
END = "M30"
END = "M2"
END = "%"
TOOLCHANGE = "T[T]"
; History
; Who When What
UNITS = mm
; Block numbering
LINE_NUM_START = 0
; Line numbering
; Spindle Speed
; Feed Rate
START = "%"
START = "G90"
START = "G71"
START = "G40"
START = "[S]"
START = "T[T]"
START = " [ZH]"
; Program moves
; End of file
END = "G0 [ZH] [F]"
END = "G0 X0 Y0"
END = "M30"
END = "M2"
END = "%"
TOOLCHANGE = "T[T]"
