Hello,
I need a postprocessor Sheetcam for my Flexicam stealth 1530.
This postprocessor from artcam does not work for Sheetcam. Can someone give any advice how to fix?
; FlexiCAM configuration file
; History
; Who When What
; JON 26/12/01 Written
DESCRIPTION = "Flexicam (mm) (*.GC)"
FILE_EXTENSION = "GC"
UNITS = mm
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.3]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3|-1]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3|-1]
; Set feed rate used for rapid moves 1000in/min
RAPID_FEED_RATE = 1000
; Set up program header
START = "%"
START = "G90"
START = "G71"
START = "G40"
START = "[S]"
START = "T[T]"
START = "G0 [XH] [YH] [F]"
START = " [ZH]"
; Program moves
RAPID_RATE_MOVE = "G0 [X] [Y] [Z]"
FIRST_FEED_RATE_MOVE = "G1 [X] [Y] [Z] [F]"
FEED_RATE_MOVE = "[X] [Y] [Z]"
; End of file
END = "G0 [ZH] [F]"
END = "G0 X0 Y0"
END = "M30"
END = "M2"
END = "%"
TOOLCHANGE = "T[T]"
Postprocessor Sheetcam for Flexicam stealth 1530
Re: Postprocessor Sheetcam for Flexicam stealth 1530
Have you tried the Mach3 post processor?
I ask this because looking at the gcode, it just looks like standard Mach3 gocde..... noth unusual gcodes.
If you want a specific post processor making, you are going to need to porvide a flexcam manual which lists all of the qcode specific to your application.
The generic ones seem to be
watch out for the tool change though...... I would comment this out until you set it up for your application as it sets the tool height == to the tool number!
- G0
- G1
- G2
- G3
- M3
- M5
- M0
- M30
function OnToolChange()
post.Text (" (", toolName, ")\n")
post.Text (" T")
post.Number (tool, "0")
post.Text (" M06\n G43 H")
post.Eol()
Hello,
I tried Mach3 postprocessor.
Z axis works wrong, mirrored.
I don't have an ATC.
thank you
thank you
You would need to give more information. Where do you call Z0? The table and all your Z depths are positive? Or is Z0 home position, as high as the spindle gets off the table? How about some actual programs from the previous software that worked? Can't actually offer suggestions if you won't provide more than doesn't work.
crystal ball required....
https://specials-images.forbesimg.com/i ... ?fit=scale
Change the settings in the post processor....
going to have to help yourself a bit I'm afraid
Two ways to fix that..... change the settings in Flexcam so it works the right way.... (up = +, down = -)
