I have been using sheet cam for about 4 years with good results. I have an issue that has developed over night. When i run PP i only get a few lines of code and the federate is zero warning. The Licence code is (removed). With a fresh install of the program posts work good until you reach the eval limit, but as it is now it will not even get that far.
I have jobs i have due and im in a huge bind. ive searched to no end with no luck. if i knew buying a another licence would fix i would buy yesterday i can not be late.
License file problem?
Re: License file problem?
Well Ive fixed the issue at least i think hopefully. I will give details after its confirmed by Les.
