I have found that it takes some fiddling with the settings to get the drilling operation to go in the sequence that I need, in pic similar to how stitching would go. Is there a way to select / set the start point, ie: the first hole to be at 3 o'clock (0) ? or noon (90) ? or anywhere I would like ?
Customize ordering of drill points
- drill ordering.jpg (62.28 KiB) Viewed 785 times
Re: Customize ordering of drill points
No way, I suppose ?
I guess I can cut and paste through the processed code manually to get the desired placement.
Thanks anyway,
Thanks anyway,
Pick the start points tool and right click on the drawing. Pick quick cut sequence. The start points will go in the order you select them.
Very nice feature, I didn't know it existed, thank you very much for responding !
That will work nicely for me.
