Post process
Re: Post process
When using this post process the torch height control only works intermittently. It is turned on and shows a command to move in Mach 3 but z does not move. So when not using the scribe I use the old post process and it works like should. There there anything can change to get THC to work all the time with this post process?
Re: Post process
What post processors are you using?
