Hi all,
I am having a problem with a very basic T shaped bracket with bolt holes. In Sheetcam, the bolt holes have the plasma cut path showing correctly, but the outside of the part remains red lines. I have checked for closure multiple times, exited both SC and ACAD, redrawn the part numerous times and get the same results. If I could post the image, it may be helpful. Any suggestions?
Thank you,
Part Perimeter - No Cut Path
Re: Part Perimeter - No Cut Path
Are they perhaps 2 different levels and you need to make an operation for each level?
[quote=WyoGreen post_id=27180 time=1588522175 user_id=1551]
[/quote
Not really sure what you are referring to, but I would like to understand. The drawing is all on one layer with two colors. One for the outline shape, and a different color for holes. Just for the heck of it, I changed all to one color and that resolved it, but it should have absolutely to do with anything. Thanks for the reply..
[/quote
It could be that you have SheetCam set to use colours as layers. When you import your drawing a window pops up with a number of options. In there is the optin to use colours instead of layers.The drawing is all on one layer with two colors.
