after an update, it's not possible to enter a negative "lead out" to prevent the plasma torch to cut same place twice.
In former times it was possible to insert " - 1,2 " mm. Now the smallest value is " 0 ".
What can i do?
Negative lead out
Re: Negative lead out
Is there NO solution?
Do you mean a negative overcut? A negative lead out doesn't really make sense and I don't think SheetCam has ever allowed that.
You are right!
After an installation on a new PC in German, i switched back to english. Then it's better to understand.
