Hi
Does anyone know is Sheetcam supports the Tracker CNC 4x4 with Command n Cut software?
I'm probably going to pick up the 4x4 nitro table, so just want to know if I can use it with Sheetcam, and how.
Is the tracker post processor incorporated in Sheetcam now?
I can't find any info on this on the web.
Does Sheetcam export a file that Command and Cut can read?
Thanks for any help you can offer.
Peter
Tracker CNC and Sheetcam
Re: Tracker CNC and Sheetcam
As far as I know Tracker is set up to use their software only. From what I have been able to find out they don't support g-code so there isn't much I can do. SheetCam can post process to dxf files but you then lose the cut parameters such as feed rate, cut height, cut order etc.
