Outside Cut Lead In
Posted: Sun Nov 03, 2019 10:02 pm
by Hellsbellsidaho
I have been trying to process the attached with the work being an inside cut other than the O's middle which is an outside cut. But the lead-in on the center of the O is leading from inside instead of outside. I grouped the outside and inside using Autocad grouping. Any thoughts on the issue?
Re: Outside Cut Lead In
Posted: Mon Nov 04, 2019 12:13 pm
That's odd. Could you attach the job file (File->save job) with everything set up so I can take a look.
For this application I'd recommend putting everything on one layer and doing an inside offset. SheetCam will automatically detect the inside of the O needs to be cut on the other side. It will also cut the inside first.
