Outside Cut Lead In
Outside Cut Lead In
I have been trying to process the attached with the work being an inside cut other than the O's middle which is an outside cut. But the lead-in on the center of the O is leading from inside instead of outside. I grouped the outside and inside using Autocad grouping. Any thoughts on the issue?
- Sheetcam Operations.PNG (25.75 KiB) Viewed 486 times
- Lead In Issue.PNG (176.14 KiB) Viewed 486 times
Re: Outside Cut Lead In
That's odd. Could you attach the job file (File->save job) with everything set up so I can take a look.
For this application I'd recommend putting everything on one layer and doing an inside offset. SheetCam will automatically detect the inside of the O needs to be cut on the other side. It will also cut the inside first.
